RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-13-2020, 04:56 PM   #1
Rumbaworks's Avatar
Donor truck tear down.
I’ve acquired a donor 2008 super duty, not exactly sure what kit I’ll be using but I also don’t have much room so I need to remove what I can to consolidate some space. What all would be recommended to pull off to use reuse? I want to retain as much oem parts as possible. I’m an experience mechanic but this will be my first attempt to convert a van to 4wd. Any tips would be helpful! Also not sure who’s kit uses mostly oem parts, I emailed AJ’s in Oregon this morning to see if he sells just brackets. His vans seem to use a lot of oem parts. Thanks everyone in advance, I’m totally new at forums and I’m the new guy around here.
Moe,
Rumbaworks is offline   Reply With Quote
Old 12-14-2020, 08:16 AM   #2
So you are converting the 2008 to 4WD? ..or you are converting another van to 4WD and have a 2008 donor van? Does the 2008 have a full float rear axle? Many 2008 passenger vans have them.....that would be worth swapping.
2000 KTM 200 EXC
Old 12-14-2020, 09:46 AM   #3
Everything you want to know about DIY 4x4.
https://www.sportsmobileforum.com/fo...are-22440.html
Old 12-14-2020, 10:28 AM   #4
Rumbaworks's Avatar
The donor truck is a 2008 f350 minus the engine, I was hoping to remove what I can use for my 04 e150 and scrap the rest.
I'll check out that thread, thanks guys.
Old 12-14-2020, 10:50 AM   #5
....ahhhh..around here a "2008 superduty" is an E-350 van....
One thing to note: The F series truck lug pattern is 8x170mm and the vans are 8x6.5"..all the way to 2014/the end.
2000 KTM 200 EXC
Old 12-14-2020, 11:25 AM   #6
If the 350 rear axle is a full floater and you're on a budget I would salvage that.
But as boy wonder pointed out you will have to run wheel adapters In the rear
[HOONIVAN]
Shaggy
Vantastic
maxx
