Old 08-02-2019, 07:55 PM   #31
Making progress on the lift kit- great turning radius and the tire clearance is looking good!
0F12DA6E-96BA-49E9-91B6-EEE8E5BCAD3F.jpg   727DAC5F-D3D6-4A4F-B1DB-FA8F26B8372D.jpg   20EB51C1-9BD1-492E-A336-1CAC2A08C045.jpg   4355623A-F52A-4F5A-828D-38D12CBF75ED.jpg   07D8715F-CC4E-48AA-A002-EF6802415021.jpg
DIY4x4guy is offline   Reply With Quote
Old 08-03-2019, 01:24 PM   #32
Brackets
Hi there
I find this link true a friend I’m close to compleat my project
I will be interested in this front spring brackets
Appreciate your time
Lole is offline   Reply With Quote
Old 08-03-2019, 01:49 PM   #33
That’s very awesome the way the red rig looks
Get me a price on the upper shocks washer and the front brackets please
Old 08-04-2019, 12:49 PM   #34
Originally Posted by TomsBeast View Post
My dislike for square u-bolts, and wanting more clearance between the axle and frame rails, and to make room for a different snubber, drove me to a completely different plate design.
Shown here before final welding, two stacked plates, top plate with hex shaped holes (to nest the bolt heads, anti-rotation) and the lower with through holes. I keyed the shock tabs into both for a strong assembly, welded top and bottom plates along their edge. Probably a lot more work than most people want to do, but I was only doing this once
For some reason I was not paying attention and thought this post was from the OP. I do like the work involved with the notched plate and shock keyed insert. The problem is the bolts are still pointing at rocks. No matter what design you make for the lower plate/clamp/bracket it still hangs below the axle. This is vital with some guys that do not want to run bigger rubber as far as clearance. The work is very niceand is still usable with u bolts!!
Old 08-05-2019, 01:55 PM   #35
Thanks for all the pm! Heavy metal headed your way!
Old 08-19-2019, 12:17 PM   #36
Life happens and I got pulled off the red van build. But back at it , got it to the alignment shop, it needs a little camber but other than that the toe and caster came out great- time to put a few miles on it and it’s going up for sale
F155C6E5-06B0-4286-A9FD-49532A72C320.jpg   71BA077E-C741-4434-A300-807A3FB65974.jpg
Old 10-05-2019, 11:02 AM   #37
There are a couple of great companies offering conversion kits. They offer complete kits.
Great to see someone offering components for the DYI person.
I think one thing that the industry needs is someone to offer parts for a person to fill in the gaps that one finds.
Leaf springs are easy to find. Brackets are harder to find.
Great work looking forward to seeing the final price
Ogre20012001 is offline   Reply With Quote
Old 05-16-2021, 09:01 PM   #38
Diy van conversion kits
Did you ever get a website going? I need some brackets bad. Thanks
Dkdod73 is offline   Reply With Quote
Old 05-16-2021, 09:06 PM   #39
Are you still on here?
Old 08-20-2021, 07:10 PM   #40
Mr 4x4 man
How do i get in contact with you to?
Gragouli is offline   Reply With Quote
Tags
4x4 conversion, diy, ford 350, off road van
