Originally Posted by mgmetalworks
I can't remember the specific wire we tapped on Jsweezy's van but what I did was check all of the wires in the Digital Transmission Range Sensor to see if any of them grounded while in P or N. I think we tapped the OSS too. It's been a couple years since I did that and the wiring on the Cummins van is totally different than the 4R75E so I can't use that as an example.
This will send me in the right direction. I will check with a multimeter on the Digital Transmission Range Sensor. I should be able to find it then.
I will use the OSS instead of the WSS/ABS. The OSS will spin faster in low range I suspect.
Thank you MG!
If anyone else has advice, please chime in.
