Originally Posted by Houstonredrider
Ins Diam Bar Diam Rate Load Install H Free H
CC860 4.03 0.81 512 1510 15.5 18.31
CC860S 4.03 0.83 549 1797 16 19.27
CC880 3.98 0.78 589 1850 13 16
CC880S 4 0.81 652 3006 12 16.6
I'm trying to compare the SSS 31's rate to the CC880s to determine how much stiffer the 31 spring is, is it 10% 20% etc
Is the CC880s rate (load) 3006# compared to the SSC 31s 5000#?
The difference in rate between the CC880 and the CC880s is confusing. The rate on the S spring only slightly higher then the non S spring, yet the Load 70% heavier on the S spring.
The S spring is .6" longer and heavier, yet when installed it's an 1" shorter then the non S spring?
Coming from a motorcycle racing background it amazes me how the auto industry is so vague about springs rates and doesn't use a common measuring method. The Jeep springs crowd is the worst for this.
This applies mostly to coil springs.
If they published the overall uninstalled height of the spring then listed how much pressure (rate in lbs) to compress it per inch, for every inch until coil bind. You could weigh the front of your van and know very precisely what the ride height would be and with the total compressed height you would know how much travel you would have left in the spring before total coil bind for every different spring on the market that fits your van. Because the springs on our vans have no adjustable preload there is no real variance. You can't preload the spring an 1" to change ride height like a race car or truck. So the spring is always going to act the same, we have no adjust ability. If it takes 1000# to compress spring A 2", no matter what van you put that spring on, it's going to take 1000# to compress it 2"
Some people like progressive rate springs, some like straight rate springs. With this measuring standard you would know exactly what you were buying and have a pretty good idea of how it was going to perform.
With this info the size of the wire, number of coils installed height wouldn't matter. The installed height is relative to each vehicle anyway.
Then 4x4 conversion and suspension companies could publish the exact ride height their system was designed for. So if you wanted to add a snow plow on the front of your van, you would know exactly what springs to buy for your custom needs. Or if you varied out of that designed height at least you would know it and could adjust accordingly.
We all want the best ride we can get in our vans, but the coil spring industry isn't helping much at all. If you pay for custom rear leaf springs they build a pak that fits your needs. You can't build a pak for a coil spring, so at least tell us what it is going to perform like so we choose which spring works for our van.
Rant over.
