Old 05-06-2010, 10:22 AM   #11
Re: Sway Bar Disconnecting and Reconnecting
Originally Posted by John & Dana
One thing to watch out for is the bushing has a metal insert which tries to work its way out occasionally making the pin and washer hard to re-install so check these and tap them back in place if they are not flush with the rubber bushing.
John
That's what I use the socket for. If you get the right size socket you can tap in the insert with the disconnect mounted making it easier to install the washer and pin. I hate to have to pull the disconnect back off to re-position that sleeve.
Old 05-06-2010, 10:39 PM   #12
Someone should see if you can use the electronic dis-connecting swaybar from a Dodge Power Wagon. Just push a button & it disconnects. Push the other button & it re-connects--on level ground.
Current vehicle: 08' Power Wagon
Future vehicle,hopefully: SMB 4x4 RB 50, Purpose built for off-roading & camping, in style of course !!!
TwinStick is offline   Reply With Quote
Old 05-07-2010, 07:32 AM   #13
Do they make anything like the anti-rock sway bar for full size rigs? Something for a F350 that could be adapted?
Old 08-08-2010, 07:29 AM   #14
I have a button on my dash that I push and my swaybar disconnects I dint need to even get out. When I need the front flex push the button it disconnects push the button it reconnects. It runs off air. It's so cool. I have it on my landcruiser all so.
Chimneyman is offline   Reply With Quote
Old 08-08-2010, 10:55 AM   #15
On a Van? I'd like to see that...can you post a few pics?
Old 08-08-2010, 02:16 PM   #16
I would also like to hear about your Electronic disconnect. I haven't seen anything aftermarket yet. I keep browsing the junk yards in hopes of finding a Dodge Ram PowerWagon (which have an elctric front sway bar disconnect. Nothing so far...
Old 08-08-2010, 04:42 PM   #17
Guys-
If you park the van on flat ground, it's not tough to re-install the links. Disconnecting the sway bar makes such a difference in comfort and ride on rough ground that even if it were hard to re-connect, it would be worth it.
Bill
P.S. FLAT GROUND!!!!
P.P.S. FLAT GROUND!!!!
NO2B
Old 08-08-2010, 05:54 PM   #18
I will get some photos some time this week when I get back in town.
Old 08-08-2010, 11:35 PM   #19
Originally Posted by Skywagon
Guys-
And pushing up the PH top isn't that bad either, but pushing a button is so much cooler
Old 08-11-2010, 09:12 AM   #20
I first designed it for my land cruiser because i did not want to lay on a muddy wet ground then get in and get my seats all nasty. so i want something that made it easy to lock in. When i was done having the sway bay unlocked push the button on on the first part of level ground it locks back up.
