thxs. If you can post a picture of your cross bar setup, that would be helpful.
The F80 is a horizontal mounting orientation which, I am guessing, means it would have to go above your crossbars and at the very outer end of the bars. This puts the awning up very high. If your cross bars are high enough then the awning mounts pictured could be used to mount the F80 below the bars. Are you considering the Eagle Model?
The F45 and Hideaway mounting is to vertical bracket/wall. How would you see mounting this to clear the slider door? Above the bars?
