Old 05-07-2017, 09:31 AM   #351
Fitz's Avatar
New Home for Nerf Bars
Post #326 showed the transition from Aluminess Nerf Bars to Van Compass Sliders. Yesterday Mark & Karen (mkkbven here on the forum) drove up from Ventura to give the Nerf Bars a new home. Their van is a 2wd version of Flint, right down to the same color and floor plan, and it was great sharing ideas and learnings with them. They will be at Overland Expo (out-of-country family commitments will keep us from attending), look them up and pick Karen's brain for some great ideas! She gave me several, next on my list this morning is to get a couple of packages on the way to me!
KN6BJX
Old 05-14-2017, 04:56 PM   #352
Fitz's Avatar
Wheel Mounting Alignment Tool
Here is one of the ideas mentioned in the post above.
MB doesn't use the wheel lug most of us are used to, rather they use a threaded stud that is completely removed when the wheel is taken off.
As you can imagine, putting the (heavy) wheel back on is a bit difficult as you hold the wheel in place and thread the stud in.
Enter Terrawagen's simple solution. https://www.terrawagen.com/collectio...alignment-tool
It's a simple matter to thread in the tool (get two, they are sold individually), lift the wheel in place letting the tool hold the weight and provide alignment, screw in four of the studs, remove the alignment tools, and then screw in the remaining two studs.
I added two of these alignment tools to the bag that contains the deep wheel sockets and the wheel lock fittings needed to change a tire. Simple, lightweight and effective, thanks to Mark & Karen for the great idea!
And don't forget, the torque setting for the wheel studs is 133 ft-lbs.
KN6BJX
Old 05-14-2017, 06:23 PM   #353
Fitz, this site can always count on you to ferret out a new trick to add to a tool bag...
EmMay is offline   Reply With Quote
Old 05-14-2017, 06:25 PM   #354
Fitz,
Do you carry a long handled torque wrench, electric or pneumatic impact wrench, or something else?
Thx,
TH
Old 05-14-2017, 07:00 PM   #355
Not to digress, but what highway pressures do you run your BFG 's at?
I have the Moto metal 8:" rims and 265/70R17 BFG tires
buggymancan is offline   Reply With Quote
Old 05-14-2017, 07:56 PM   #356
Fitz's Avatar
Tire Pressure
I run the front at 50 and the rear at 70, see post #335 above for a bit more detail regarding tread wear.
BFG KO2 265-70R17's
The van weighs 8,600 lbs. and handles really well at these pressures.
KN6BJX
Old 05-14-2017, 08:05 PM   #357
Fitz, did you see my post #354 above?
Old 05-14-2017, 08:07 PM   #358
Fitz's Avatar
Tire Tools
Originally Posted by TomH View Post
Fitz,
Room and extra weight is a consideration, thus I only carry a long handled 1/2" breaker bar for this purpose. The impact gun and the 1/2" torque wrench both live in the garage, but I broke a couple of the studs free and put them back on with the breaker bar (and then checked the torque) just to get a feel for it so if I need to do it away from home I'll be able to get it close enough to get back on the road.
KN6BJX
Old 05-14-2017, 08:19 PM   #359
Fitz's Avatar
Tool Kits
We've had the van for 8 months and 11,000+ miles so far. This will be our first full summer with it and I'm looking forward to seeing what new things we learn that we need to have with us along the way. I'm thinking a future post will take a look at the details in the tool bag(s), but not until we have gone through all four seasons of use!
KN6BJX
Old 05-17-2017, 07:34 AM   #360
Fitz's Avatar
Re-Torque!
Originally Posted by BroncoHauler View Post
Looks great. Be sure to check the u-bolts once in a while. As new spring packs move around and settle, sometimes the nuts need to be tightened up.
Good advice that was seconded by member tig in an additional comment.
I took the torque wrench under the van this past weekend and found 7 of the 8 u-bolt nuts holding the new rear leaf spring pack were below spec. Nothing dramatic, but definitely a best practice to go back and re-tighten. Thanks for the tip!
KN6BJX
Tags
carport, molding trim clips, recovery ramps, skid plates, suspension upgrade
Vanny Devito
dick
Otter
