The rear passenger door handle cable has been broken since February. Finely got around to fixing it today. This thread was very helpful. I used the Dorman replacement cables that are just like the OEM cables.
It was easy once I got the all the pieces out of the door. Here are some tips.
1. Be sure to remove the rear door speaker to gain access to the license plate light. If you don’t there is a good chance you will break the light bulb housing.
2. The electric lock actuator is held in place by a spring clamp. Use a flat bladed screwdriver to open the clamp. Do one side and then the other.
3. The use of a small needle nose pliers is helpful when removing the existing cables from the latch mechanisms.
4. You will need to remove the spring clip that holds the shaft on the back of the lock.
Larrie
