Old 01-06-2012, 05:39 PM   #21
Re: Elusive Eli Brackets
Gentelmen,
Sorrry for the delay in posting/ pm ing those of you that are intrested in brakets. It had been a busy year. I am not making the brackets any longer. It was too time consumming for me and had little to no profit (not that that is why I was doing it) and the logistics of shipping all over the country was a pain. I have talked with Jage and Ujoint about taking on the prodject. I will be sending Ujoint the bracket specs and the blanks. I feel that he has the best skills and shop pluse he already ships his products all over. I hope to have this done soon so that those that want them can get them again. If you can frabricate, you could buy the T1 VW mounts from Fiamma and spend a day or two modifying them. That is how I started. I will pass on to Ujoint the need to bend the top mounting plate out a degree or 2 to help clear the pop tops.
Eli
2006 6.0L EB 4x4 Ford Transformer with custom rear platform bed, AKA The Sliver Fox, AKA The Sliver Bullet
PecksTank is offline   Reply With Quote
Old 01-06-2012, 05:54 PM   #22
Geoff, they're welded though the back of the stainless plate. The heads of the bolts fit into the large holes SMB created in the body panel, then the threads protrude as shown. We were thinking of putting the plate behind the the body panel but we felt that that would create seal issues along with rattles, etc. Too much downside for any upside in appearance, plus i sort of like the military/aircraft look of it. Doesn't make the brackets look any worse, at least, IMO.
The plate (2-1/16" stainless sheets so 1/8" total, s/b plenty stiff to distribute the weight, which is mostly outward on those brackets, btw) is then attached to the body via the screws as shown, sealed up with 3M body joint compound.
webbmac is offline   Reply With Quote
Old 01-06-2012, 07:12 PM   #23
Originally Posted by ANZAC
Just fyi, my van is 10 years old, and I haven't seen any cracks.... where do they form?
My body panel had cracked sideways on my middle bracket. Seems like a popular occurrence. That and all of my other 'bolts' were loose and there was realistically no way to tighten them, don't know if the rubber/neoprene hardened or something and was not gripping the edge of the holes right. I could not risk the awning coming off in Mexico so we came up with this fix fairly quickly. I'm sure there are more elegant fixes but this is what I came up with in a pinch.
Old 01-06-2012, 10:12 PM   #24
vandiesel's Avatar
Eli, would you be willing to send the drawings out? I was at my close friends machine shop today and he can easily make these. If we had drawings it would save a ton of time for both of us. I kinda figured it wasn't a huge money maker so hopefully sharing the drawings won't impede on any get rich quick scheme. . The only thing I have to go on is the picture of your first modded set of the fiamma ones that is not to scale.
Thanks,
Brad
Old 01-12-2012, 01:28 AM   #25
cellularSTEVE's Avatar
Whoever ends of making them, PM me as I will take set.
steve
Old 01-12-2012, 09:18 AM   #26
Likewise!
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 01-14-2012, 12:59 PM   #27
Mahukaawe's Avatar
I too would like to get a set.
Thanks.
09 E350 EB 6.0PSD SMB 4x4 kind of a 61 layout
02 F450 Flatbed 4x4 7.3 PSD
08 F150 5.4 ltr 4x4 Daily Driver
77 Orig Bronco in rebuild mode "uncut"
76 Orig Bronco rebuilt & driven weekly
71 Orig Bronco rebuilt & 4sale gots everything on it
Owned a jimmy once for about 6 months.
https://www.tropicalgardensofmaui.com
https://www.mauicabins.com
twitter @runnin6mpg
Mahukaawe is offline   Reply With Quote
Old 01-14-2012, 02:48 PM   #28
I'm in for a set ... an awning too, I guess.
salivan is offline   Reply With Quote
Old 02-08-2012, 11:54 AM   #29
Tapatio's Avatar
Any updates? Waiting for the brackets before I purchase an awning.
Callsign KK6GIY
Old 02-08-2012, 03:37 PM   #30
vandiesel's Avatar
All, I'm sorry about my delay on the brackets. I still need to take my actual awning over for fine tuning before the brackets get made. I have been slammed at work and haven't been able to. I should be able to get over to the machine shop this week. Stay tuned.
Brad
