Old 03-13-2019, 11:01 AM   #11
BenJJ's Avatar
Originally Posted by bfolens View Post
I think the easy way to start would be to 3D scan a bush version and clean it on the desktop. After it is just a 3D printing;-)
I have a brand new set of rear flares in my garage I am trying to sell. You could borrow them (or buy them ) for a 3D scan if you want.
BenJJ is offline   Reply With Quote
Old 03-13-2019, 11:22 AM   #12
dirtanddogfur's Avatar
I do a lot of 3D printing at work. PLA is not a terribly strong material and the melting temp is also quite low. For example, if you were to paint a PLA part black and put it in the sun, it would deform.
Also, unless you have access to a 3D printer (as in for free), it is probably cost prohibitive.
ABS would be a better option but, is pretty bad when exposed to UV. Paint might help here.
If you can find a printer that prints ASA, you might have better luck. Strong like ABS but UV stable.
In terms of glueing parts together, I have found good ol super glue does a great job and even a thin coat 'painted' over thing sections can increase strength immensely.
I 3D printed some rack pieces for a Rhino Rack tray to hold oars. They were ABS. I did a thin coat of epoxy, threw them under vac, sanded and painted them. They have been in the sun for about 12 months and still going strong!
EDIT: Another possibility would be to print an overmold and use fiberglass/carbon fiber to form the part.
2012 E350 SMB/Quad Van
2021 Chevy Colorado ZR2 Bison
dirtanddogfur is offline   Reply With Quote
Old 03-13-2019, 12:50 PM   #13
Bushwacker would be foolish not to have strong patents on $20 pieces of plastic they charge several hundred for. They probably have a great corner on ice water in Alaska as well.
Old 03-13-2019, 01:46 PM   #14
bfolens's Avatar
I checked this yesterday via patent google search. There is technical design there.
Anyway, the plan is not to sell it (at all) or really copy paste it. Just starting from a model helps.
I need to figure this a bit more but will update this thread if i a coming to something.
I google this a bit too, much ne I found a guy doing this for Toyota.
Just need to find the time;-)
Ford Econoline 150 - 2001 - 4.6l - GTRV
bfolens is offline   Reply With Quote
Old 03-13-2019, 02:49 PM   #15
TomsBeast's Avatar
Do you work in that field?
Old 03-13-2019, 03:39 PM   #16
I am wondering if it might be easier to start from scratch. Typically, scanned models come in as 3D point fields (mesh cloud) or STLS. Those can be tough to work with.
Might also be easier for patent protection if you can document a new(-ish) design.
Old 03-13-2019, 04:28 PM   #17
bfolens's Avatar
I do not work in that field but kind a good tech oriented;-)
I have some printers at home and play with it a bit, but nothing to professional level.
Old 03-13-2019, 09:21 PM   #18
Gooseberry's Avatar
If you have a sliding door I have a set of rears I need to find a home.
Old 03-13-2019, 09:26 PM   #19
bfolens's Avatar
Thanks for your generous offer but I have passenger doors.
Old 03-14-2019, 08:52 AM   #20
Bushwacker has a monopoly on E series flares...nobody else makes any kind of flare for them, and the market is small, thus the high pricing. That said, they do occasionally go on sale. I've never paid more than $450 per set of 4 shipped and taxed. Put them in your Amazon wish list and you will get an alert when the price drops.
I think it would be cool (and perhaps profitable) to 3D print a variation that looks more off-road ready than the mild, stock-looking Bushwackers. Something with exposed screw heads like these Tacoma flares:
Poptopper is offline   Reply With Quote
Ford Zilla
Steve C
Tatonka
gephoto
