Advice on process steps for repairing roof/gutter rust issues
Hello All, Thanks for the detailed information here in this post. I've done a paint/rust removal once 5 years ago with our trusted shop, but it didn't involve removing the bondo at the gutter-roof joint. The rust has creeped back again and I wanted to better treat it.
I just wanted clarification on how it would work if I did some of this prep on my own and then took to our shop to paint.
1) Remove existing paint on roof side
2) remove bondo at joint.
3) remove paint on gutter
4) sand/treat rust with one of the products mentioned in this post
5) prime paint metal if the rust treatment isn't also a primer.
My question now is what is the order of reapplying things to finish:
5) Paint Gutter and roof area with paint and heavy clear coat
6) apply 3M 5200 to joint area between gutter and roof.
Not sure if it should be this order above, or:
a) rust treat/prime metal
b) apply 3m 5200 to joint area between gutter and roof, then
c) paint gutter/roof are with paint and heavy clear coat.
Any input from the experienced folks on this forum would help a ton to help me determine order of operations and how much I would do myself vs have the shop do maybe.
