I think the other switch on the thermostat is for fan control, which I expect is not hooked up. In any event, starting the Starcool in engine running mode and shorepower mode start off the same. Turn the switch on low, med, and high this should turn on the front condenser fan. With the factory AC on, the unit will be running in combined mode.
At that point if the engine is not running, the thermostat should be enabled. It is normally locked out while the van is running. If the conditions of the thermostat are met, this will enable the compressor, solenoid valve, and also enable the auxiliary condenser blower.
