Old 01-23-2016, 10:47 AM   #1
TomsBeast's Avatar
Bilstein shocks
Bilstein 5125 shocks, front, pair, they fit UJOR 4x4 conversion w/4" lift. Shocks are 18-1/2" extended, 12-1/2" compressed.
Used in good condition, seals tight, shafts like new, eye bushings great, nitrogen charge good, correct valving for the front of E250/350.
I was very happy with these, but I built some custom upper and lower mounts that required longer shocks, otherwise they'd still be on the van. I replaced them with the same 5125 series shock, that's how much I liked the ride.
You will need UJOR upper mount kit FS001 or similar, and stock Ford Ubolt spring plate or similar for the lower.
$90 + actual shipping cost
Old 11-30-2018, 02:33 PM   #2
TomsBeast's Avatar
price reduction to $20
I have too much stuff; $20 plus shipping
Old 12-20-2018, 04:40 PM   #3
Will these fit a 1991 E250? I'll take them if they do.
nortryder is offline   Reply With Quote
Old 12-20-2018, 06:48 PM   #4
TomsBeast's Avatar
Only if it has a Ujoint Offroad 4x4 conversion, which uses a non-Ford top shock mount
Old 12-20-2018, 09:27 PM   #5
ctb
ctb's Avatar
Send a message via AIM to ctb
Here's a pic that John (Quadvan) sent me when he was installing the 4x4 On Sporty....put on two Bilstein for extra support...
'13 MDX 'BigBlackmobeebs'
'01 Lexus 430 LS 'Luxobeebs
'20 Tacoma TRD OR 'Tacobeebs'
Old 12-20-2018, 10:54 PM   #6
Bbasso's Avatar
Negative ghostrider, ujoint only does 1992 to current.
Rob.
Current:
And had three other E350s...
Old 12-21-2018, 05:38 AM   #7
Nope. I have just a plain old 351W 2WD. Too bad.
Old 12-21-2018, 10:54 AM   #8
TomsBeast's Avatar
Yeah, I missed that Nortryder said he has a 1991
Anyhow, for anyone else interested in these, they are specifically for the UJOR mounts and a 4" lift. The UROR upper mounts weld to the Ford coil spring buckets.
The lower mounts can either be Ford/Dana 60 (99-04 vintage) or UJOR lower mounts.
The finished Ujoint Offroad shock set up, that these work with, looks like this:
Old 02-08-2019, 03:22 AM   #9
I’ll take PayPal
zlivewire is offline   Reply With Quote
Old 02-08-2019, 09:40 AM   #10
TomsBeast's Avatar
Originally Posted by zlivewire View Post
I’ll take PayPal
They're yours. PM sent
Vanzilla
Glenn P.
Agnes
ranchero
