FS 2005 E250 SM Quadvan 4x4
2005 E250, 137,000 mi. $58,000 Located in Boulder, CO
Meticulously maintained and loved, includes historic service records and user manuals.
Sportsmobile build w/ Penthouse top (full-size upper bed) and lower gaucho benches which convert into 72" x 54" bed.
Seat belts for 8. Both front seats swivel. 2 additional captain chairs currently not installed (included with van).
Day/night blinds and screens for windows. LED lights throughout, including side door outside flood lights.
Lots of storage and very roomy inside. 2 dinette tables w/ tri-pod stand for outside use.
4x4--
Quadvan (Lo4/High4)-All Ford OEM Parts, LS Rear Diff., Bilstein shocks and SpringWorks rear suspension upgrade.
New BFG KO2 LT265/70 R17 tires (~5k miles). Full-size spare on matching wheel (Aluminess swing-away mount).
Accessories--
1-Up Bike Rack with Kuat Pivot Swing-Away. (bikes not included!!)
2 bike racks on roof (can accommodate 2 more)
Full-size locking Thule Cargo Box (fits 29" front wheels)
Water--
10 Gallon internal fresh water tank (mounted under driver's side bench seat) w/ all internal plumbing and internal & external water fill ports.
12 gallon grey water tank (mounted under the van where the original spare was). External quick drain valve.
Stainless steel sink with 12V Shurflow pump. Very easy and quick to winterize (takes minutes)
Includes all hoses/connectors to hook up to the RV site or city water/sewer.
Electric--
X2 Group 31 AGM battery (100 AH) under warranty; 1150 CCA (Very powerful...can jump start engine battery if accidentally left headlights on)
12V and 110V fuse/breaker panels
Battery separator- automatically charges AGM while driving
Shoreline power (exterior outlet) provides 110V power to internal/external outlets & charges AGM battery
80 Amp Zamp Solar Panel with MPPT Controller charges AGM
Charge Wizard battery conditioner decreases charge times and prolongs battery life
Norcold 12V Fridge/freezer- upgraded model with super quiet Danfoss compressor
Starcool Aux A/C unit mounted under the van with adjustable vents toward the rear of coach- powerful and efficient.
Upgraded stereo with Bluetooth/Apple CarPlay and a switch to run off either engine or AGM battery
