Are you sure it's not the PH springs rattling? That's very common. The channel that the springs reside in is lined with headliner foam/fabric that is glued down with contact cement.
It's quite common to have the springs peel back this fabric when compressing when the roof is raised, leaving the springs to rattle against the steel channel that they sit in.
Both the springs and the crossbars are loaded quite heavily when the roof is down.
Are the cross bar pivot bolts loose?
