Originally Posted by Scalf77
Under the gray fabric panel behind/above the seats , the panel goes across the van, If I remember correct only a couple of screws. The fuse is over where the wires are going up to the top.
I have a 2006 & This is exactly where I found mine (after shorting out the fuse by accident).
When the top is up, there is a 4 or 5" ledge that spans the width of the pop top canvas - above the two drivers seats. Probably just fabric held down by a couple small screws. If you unscrew the section above the drivers side and push back the fabric, you should see the fuse holder.
