Old 12-06-2019, 10:24 AM   #11
chrisbaffico's Avatar
Thanks Greg!
Must be float voltage then -when the light is yellow the voltage is in the 14s (charging) and when green the 13.28 (float)? I will do what you suggested, I don’t have a load tester -any suggestion on what to connect to them? I’ll report back after I do that. Batteries have been flawless and would expect the voltage you suggest.
1999 Ford E350 EB PH
7.3L V8 Powerstroke Diesel
Custom flr plan like EB44
Agile Offroad 4x4
chrisbaffico is offline   Reply With Quote
Old 12-06-2019, 08:55 PM   #12
Originally Posted by chrisbaffico View Post
Hi 1MOBITE, yes that is the voltage after being off the charger for a day. The serial numbers are a couple numbers off and where purchased at the same time. I can send the numbers to you later today. PM me with your best contact information. Thanks
Sending you a pm with contact number.
1MOBITE is offline   Reply With Quote
Old 12-08-2019, 12:42 PM   #13
There are three of these in a clients van (an ex A&E Ambulance) that I am doing some electrical work on, they are dated 2017, current resting voltage after a week is (I hope) a healthy 12.80V. I think they are an excellent battery.
They are securely mounted vertically in a 100% 'will not kill you' steel frame
We don't like UFOs is our vans do we!
QED:
https://youtu.be/z6ifuVMeUrA
CriftinsCampers is offline   Reply With Quote
Old 12-18-2019, 10:09 PM   #14
*****UPDATE*****
Hi all,
The batteries are still for sale. I met with Chris at Deep Cycle Battery San Diego for testing. Load test has been done at 700 amps for 30 second. Charge remained at 12.95 before and after test. I was told that the cells are clean and clear with no obstructions. Although not starting batteries, deep cycle batteries are 400-600 Cold Cranking Amps. A CCA test was performed and they were 527 and 549. I was told the batteries are like new. Anyone that is interested can meet at the shop for another test or a shop of their choice. This should ease anyone’s mind as far as buying these used batteries. Thanks
Agile Offroad 4x4
Old 01-10-2020, 05:22 PM   #15
****sold****
Agile Offroad 4x4
