6.0 Diesel Van project (Built Motor)
Hey guys!
Ok So last may I pulled the trigger on my second van after living out of my self converted E-350 handicap van for 4 years. And after a very long year of waiting for parts, and waiting for my cousin/mechanic to move shops, and more time waiting for parts, and lotttttt long nights filled with blood, sweat, and tears, my new van drives and is on the road!
This was basically a balls to the wall project, the body was coming off to do significant motor work (heads and “bulletproofing”), so it kinda snowballed into a “let’s replace everything but the frame and body” build, complete with a 6” 4-link 4x4 swap with coil overs 😎
Annnnnd then my motor ended up being bad (I bought a non running 6.0L ford, so I guess I should’ve expected that), so I bought a new motor! And a new transmission…
And about $35,000 worth of other parts….
So check it out and give me that sweet, sweet, dopamine.
Here’s the build List!
All the work was done by me and my cousin who is a Diesel Mechanic.
And Idk if Tim’s on here, but I got the 4x4 kit through him at Timberline Vans 🤘
Engine:
Warren Diesel short block: stage 2 cam & coated pistons
KDD 6.0 o-ring Heads
ARP Head studs
ARP top head bolts
ARP balancer bolts
Kc Jetfire Stage 2 Turbo
Warren Diesel 175cc/30% injectors
Odawg S3R Intake Manifold
Sinister Regulated Fuel Return
AirDog II 5g
Sinister Diesel 48v FICM
Sinister 320AMP Alternator
KDD Chromoly Pushrods
KDD Stand Pipes and Dummy Plugs
River City Diesel Thumper HPOP
New OEM front cover and lpop
A highly modified Bulletproof Diesel e-350 oil cooler set up
Fully custom 4” cat back exhaust with 6” TSO hexagon tip (powder coated)
Edge CTS monitor
SCT x4 tuner w/innovative tunes
PHP FICM tuner
Transmission:
Warren Diesel Competition+ 5r110 transmission (600hp)
Stock stall speed torque converter
ATS Transmission Pan (powder coated)
Custom transmission lines with TruCool Trans cooler
Suspension, Steering, & axles:
6” 4 link 4x4 kit: Timberline Vans (all powder coated)
Elka Coil-over shocks
Custom Heavy duty Rear leaf springs
2015 f350 front and rear axles w/Elocker and 3.73 gears
Rebuilt NV271 tcase
E350 Redhead steering gear box
ATS Rear Diff Cover (powder coated)
ATS Front Diff Cover (powder coated)
Warn Locking Hubs
Helwig sway bar
All new body mounts
Custom blue rear brake lines from Spiegler Performance
Custom front and rear driveshafts
New brakes, rotors, and calipers
2022 f250 tremor wheels and tires (35’s on 18’s)
Honorable mentions and extra goodies:
New radio and speaker with tweeters (vans don’t have any stock tweeters)
All New sound deadening/heat shielding in the cab
Wrapped exhaust
Rust removed from frame and underbody, then truckbed lined
Every single sensor replaced
Any OEM part that looked remotely questionable and can’t be easily swapped was replaced
