I wouldn't worry too much about the water line either. Ask yourself what's the worst thing that can happen if the water line springs a leak....it's likely that the interior gets soaked.
I develop medical devices for a living, and we spend countless man-months doing hazard analyses and failure analyses, many times right down to each component on a circuit board depending on the risk to the patient or user. The risk is the severity of the failure multiplied by the occurance/probability of the failure.
I'd guess a failed BMS, or an unprotected short circuit in a battery cable would be your worst failure.
12VDC wet is not a safety hazard. Wet 120VAC is!
Looking at the attached picture you can see what looks like 120VAC having a possibility of coming in contact with water. I can understand the hesitancy or re-orienting any of the current install for a low probability hazard.
So some type of plastic or PVC over in the area right below the 120VAC distribution panel would help to prevent any possible damage to the water line in that area as well as deflect any spray away from that area in case somehow a leak developed in that area.
The worst thing is that you would probably blow a circuit breaker if water got into the invertor. If the floor of the van saturated it is possible to get an electrical shock if the AC was not grounded but that bus bar seems to be
grounded to chassis (I suspect??) so that may not really be possible.
.concerns.
