Thanks senorkc, I will be running the stock tires on my e350. The reason I am lifting is not for larger tires or excess weight. I need a couple of inches more clearance because I have a mini-split attached to the underside of floor just behind the differential and also because I will be installing a motorcycle rack into my receiver hitch. The van is an EB, so the overhang is already quite a bit. I am just worried about scraping something. The van is actually running fairly light. With the bike on the back and the van loaded I should be in the neighborhood of 1100-1200lbs. That includes my solar, batteries, heat-pump, water, tools, appliances, cabinets, bed, etc.
