Old 01-24-2017, 09:12 PM   #31
LenS's Avatar
Last pics show the ladder as I installed it on the Green TARDIS. It mounts on the drivers side wheel eyebrow.
Len & Joanne
The Green TARDIS
Old 01-24-2017, 09:16 PM   #32
LenS's Avatar
Construction pics. Sorry no measurements. Went mainly by eye and having even spacing on steps.
Len & Joanne
The Green TARDIS
Old 01-24-2017, 09:20 PM   #33
LenS's Avatar
When I got to bending the top of the ladder I did it by fitting it the van gutter. Bent it so it was about 1/8" short. That provided tension on the unique gutter attachment. Very simple but requires ladder to be under slight tension to stay in place. It has worked out fine. I did cut up an old bike tube to put rudder under it so it didn't scratch the van paint.
The bends were located just to keep the ladder about equal distance from the side of the Chevy van. More or less an eyeball job. Bend, fit, bend, fit, etc. Looks like put a bend just below the second step and another at the forth step.
Len & Joanne
The Green TARDIS
Old 10-23-2018, 09:57 PM   #34
ladder
where do i get those upper brakets for the ladder.
im in the process of building mine.
thanks so much.
any ideas will be welcome
fedeavakian is offline   Reply With Quote
Old 10-24-2018, 10:15 AM   #35
LenS's Avatar
I bought 1/8" x 1" flat stock, heated it and bent it to shape. Easy to do if you get the stock red hot where you want to bend it. Also requires a vice.
Len & Joanne
The Green TARDIS
Old 10-24-2018, 10:49 AM   #36
Wow, talk about bringing a thread back from the dead! It''s timely though, I am in the middle of fabricating some EMT as a template for a roof rack / limb lifter system. Did you find it easy enough to notch the tubing by simply holding it down, between a couple pieces of wood? Do you think that set-up would be sturdy enough to notch just the end, rather than starting in the middle of the tube?
Old 10-24-2018, 11:51 AM   #37
LenS's Avatar
The method I used to notch the tubing was the same as I saw in posts by others who made EMT ladders on SMB forum. The drill press fixture method was very easy and very accurate. I wanted the joint fit as tight as possible to assure a strong brazed joint. The notching method worked out quite well.
Len & Joanne
The Green TARDIS
Old 10-24-2018, 02:58 PM   #38
Twoxentrix's Avatar
I bought several from Aluminess for a project I'm working on - referring to the gutter mounts they use.
