Old 03-25-2012, 05:55 PM   #1
Electrac Locker 4.56 gears and 35 spline axles
I have an 01 7.3l E350 Quigley van with 33" tires (285/75/16). It came with 3.55 gears and open differentials. The gears were just too tall for the tires and the motor simply did not like overdrive. Those of you with similar ford transmissions might know that we have extra high overdrives that are .71:1. I used grimmjeeper.com to calculate what ratio would be close, or just a little lower than a rig with 4.10's and stock tires. Since my van actually liked to run down the highway in drive with the 3.55's, I decided 4.56's would be perfect. They would put me right at 2300rpm going 70mph. I also found Electrac lockers front and rear for $400 a piece thanks to Randy's Ring a Pinion (sorry, I think I got the last ones). I wanted the experience of gear setup, so I decided to purchase a diff spreader and setup bearings, which I would definitely recommend to anyone considering tackling this job. This being my first ring and pinion setup (I had expert help from a friend), it took quite a while, but well worth the time and money spent. Plus, I know they were done right. As most of you may know, our stock full float Dana 60's are 32 spline and diff choices are limited. But, $300 can get you cut to fit 35 spline axles which allow you put in pretty much anything you want. No spindle boring is necessary, they fit right in. I couldn't be happier with my choices and anyone that has questions is more than welcome to ask.
Dreaming since 2000
discotew is offline   Reply With Quote
Old 03-25-2012, 07:11 PM   #2
Gnarvan's Avatar
Re: Electrac Locker 4.56 gears and 35 spline axles
What engine do you have and what size are your tires?
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 03-25-2012, 07:22 PM   #3
Sorry, forgot to mention that. I updated my post.
Dreaming since 2000
Old 04-20-2012, 09:48 AM   #4
After using the front Electrac for a little bit, I'll comment how awesome it is in the back. But, It's a little too aggressive in the front. I'm sure the truetrac, true trac, would be no different. I'm thinking that a selectable like the new E-locker or and ARB would have been a better choice. My concern is that I won't be able to use 4wd driving on snowy roads at speed anymore. I might not need 4wd though, with the amount of traction I now have at the rear. 4.56's and 285's are awesome, plus I can go to 315's soon. I still get 16mpg and I have plenty of power.
Dreaming since 2000
Old 04-20-2012, 02:11 PM   #5
Can't you just leave one hub unlocked?
Old 04-20-2012, 03:24 PM   #6
You should order some snow, so I can find out! I'm not sure really. Anyone have any experience with Truetrac's in the front? Thanks for the idea daveb!
Dreaming since 2000
Jim Bridger
wander
Priscilla
DocMP
