Re: Penthouse Ceiling Retrofit
That was the primary thought, secondary was it took my a couple of weekends, and living in the the Northwest I expected rain, by doing the second washer on the inside I was able to snug everything up with out putting it all back together. I attached the strips with glue and screws, it is a lot easier screwing into the top when you can actually see what is there. I no longer have the saggy corners with screws pulling out, which is pretty standard with most SMB's I have seen.
I probably did not need the inserts, I could have just screwed into my new plywood strips. Using the inserts actually took more effort to get every thing lined up. I used #8 wood screws, I believe 1" as I was going through 1/2 plywood. They were most likely Kreg or McFeely's, as far as brand. Just take your time, when you pull down the top it becomes pretty clear how it works. I used 4x4's and 2X4;s across the bed rails to block it up.
