Haven't had much time to mess with this thing due to selling my other van and work etc.
I did end up finding time to do the plugs/wires/cap and rotor and replacing the air filter. I also checked base timing and its right around 10*btdc
noticed the alternator cable was in pretty rough shape lol
I went ahead and made a new one.
I think it may have become more damaged when I removed the alternator to mess with the EVP sensor as the van was charging erratically and had a fluctuating idle after that work was done.
Seems to be less electrically erratic now and the lean code 172 is back.
It has good fuel pressure and the EGR seems to work properly although I need to do more testing to make sure it isn't sticking open.
I was worried the cats were clogged but there isn't any backpressure in the exhaust so I can rule that out.
The AIR (smog pump) system seems to be working properly as well, it does seem to be switching from the heads to blowing into the exhaust after the engine warms up.
The van seems to idle well, it sounds good but when you put your foot into it it pings pretty good and doesn't have hardly any power.
I need to get it smoke tested.
I will have more time to get into it going forward
Should be ordering 4x4 stuff soon as well
Mitch
