Old 02-21-2021, 11:23 PM   #1
Rear ac removal
OK I’ve been reading to the post about rear AC removal and dual system and dual a compressor iand whether or not to remove and all this but I’ve only had a bus a couple weeks and I’ve checked and I can’t see anotherCompressor on the system so I’m assuming it’s a dual system with one compressor does anybody know if that’s correct? That’s the first question the second question would be whether I use a block Off kit to remove the back unit or something else because it looks to be like you use that kit if you’re going to keep the unit intact in case you’re going to use it a future day I don’t know? Any kind of information would be helpful like I said we are newbies and we need a lot of helpnif there’s anybody nearby ( so cal) or that has advice send me a message please please please 😊
HAPPYhappy04 is offline   Reply With Quote
Old 02-22-2021, 06:24 AM   #2
BrianW's Avatar
Need more details:
Do you have an actual Sportsmobile with the rear aftermarket Starcool AC system, or just a Ford van with the OEM Ford rear heat/AC? Or, if you have a “bus” you could have an entirely different third-party system.
Dusty
capnkurt
Betsy
darryldickie
