Originally Posted by RVnewby
What are the dimensions of the opening? Did you have to do anything to the floor before you secured the Iceco slide? How did you secure the slide? What did you need to do to the cabinet?
Sorry, just now seeing this. The old norco fridge takes up the entire space. So that's the size of the opening. But once I removed it, I also removed the wall section behind the driver's seat for some more room. You could just screw the slide to the floor but there are two mounting bolts going through the floor that help hold the cabinetry in place and the one closest to the sink is in the way if you want the replacement to fit snug up against the cabinet. So I simply made a frame of 1/2" x 4" wood that I secured to the floor with screws and then screwed the slide onto that.
That's basically it. Let me know if you need anything further.
