Old 01-21-2017, 10:31 PM   #21
Roccon: If the roof fasteners are leaking, consider replacing them with stainless fasteners when you redo them to fix leaks....I used stainless everything, new butyl, and some stainless sealing washers from Mcmaster....no leaks.....
BTW I just started a new job and I'll be in the Escondido area frequently..maybe closer than south OC for you if you'd like to get together.
You may want to consider a tarp or some visquene plastic for the next couple of days if the van will be outside......
Old 01-21-2017, 11:29 PM   #22
Took your advice, just put a big plastic painters sheet between the ph and the roof. Hopefully that keeps it dry during the next few days.
Roccon99 is offline   Reply With Quote
Old 01-22-2017, 08:04 AM   #23
Bummer. Your canvas is probably permanently stained. I hope you get this figured out soon. It's painful to see and hear.
When someone in San Diego is looking for dry weather I think the armageddon may be imminent.
Old 01-22-2017, 08:49 AM   #24
Yeah, definitely a bummer. But, I'm trying to stay positive. Reading through boywonders post about popping his top has been helpful. At least I know it can be fixed. As far as the staining...I'm pretty sure most of it will be permanent. But, I'm more form over function anyways - I don't mind if it looks a little funky as long as it does its job without leaking.
No kidding!
Old 01-22-2017, 09:00 AM   #25
rallypanam's Avatar
Also, just to let you know. SMB in Fresno will take it apart and replace canvas for about $2500, and sell you just the canvas for about $900 - but you sometimes have to talk them into it.
Old 01-22-2017, 09:02 AM   #26
Sorry to hear about this. Personally, I would send those pics back to the dealer and have a serious discussion with them. There was clearly a longer term issue than leaving the top popped overnight, and the sealer over the bolts is evidence they knew this. I think they misrepresented the condition of your SMB.
Old 01-22-2017, 09:29 AM   #27
Like I mentioned, I'm not too bothered by the staining as long as I can get it working properly going forward. But, that's good to know as a last resort.
I can certainly try (and will), but they went on and on about the "as-is" conditions, etc, and I'm sure they'd do just about anything to avoid paying any amount.
Old 01-22-2017, 03:13 PM   #28
On my last 04 SMB I noticed similar staining after a rain in the corner similar to the one pictured. As I pulled the screws in the corner I realized that the thin headliner plywood was trashed from being soaked. It literally crumbled in my hands so I imagine it had been getting wet for quite some time. I pulled the headliner and let everything dry out and rebuilt the interior of the PH. I also Raptor lined it since it was cracks in the gelcoat that caused the leaks.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 01-22-2017, 05:34 PM   #29
Thanks for the input @saline. When you rebuilt the interior did you use a similar process to boywonder (removing the entire PH from the springs/roof and then reattaching after fixed?) How long did it take you from start to finish?
Old 01-22-2017, 07:48 PM   #30
http://www.sportsmobileforum.com/for...r-ph-9707.html
Hopefully it's still holding up. If I had to do it over again I would have made the panels about 1/2" less in thickness. It somewhat interfered with latching the rear as snug as it was from the factory.
Desert Solitaire
2003 7.3L EB 4x4
