Old 06-21-2021, 02:48 PM   #211
Justgosurfin's Avatar
Yep. I just had a 5th last week and reached out to the fabricator. I値l see if he can do an extra set.
Justgosurfin is offline   Reply With Quote
Old 06-21-2021, 06:27 PM   #212
Originally Posted by moorefc View Post
I did PM you a while back and now have another Sportsmobile friend who would like a set. So if I order 2 will that make the needed order cut?
Thought I would try this on the thread rather than PM
thx
Second order for you is approved. I値l hopefully have them in a week or 2 and will send a request for payment when he gets them done.
Old 06-21-2021, 06:53 PM   #213
moorefc's Avatar
Great! I am in.....Thanks
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 06-22-2021, 02:18 PM   #214
Greetings JustGoSurfin -- not sure - Am I still on this list for S/S T-Nuts ?? I had previously sent you a PM --
Old 06-22-2021, 02:49 PM   #215
Yep. I致e got you on there Russ.
Old 06-27-2021, 06:31 PM   #216
DosMars's Avatar
I'd like a set as well if you can add one more onto that order?
Sending a P.M. now
-Mark
Test test test, this is where the signature goes
DosMars is offline   Reply With Quote
Old 06-28-2021, 06:21 AM   #217
Hey Mark, I値l just messaged the fabricator to see if he has enough material to get you in on this batch. I値l let you know when I hear back.
In the meantime can you please email me your shipping address, number and a preferred method of digital payment or check. John@nevermonday.biz
Old 06-28-2021, 08:25 AM   #218
DosMars's Avatar
Will do, thanks
Old 06-30-2021, 06:28 PM   #219
DosMars's Avatar
O.K., so my t-nuts are on their way (thanks John!)
Question -what is under that section the handles are attached to? Is there anything under tension I should know about? Is it just unbolt/remove the old, clean it up, wrap the underside of the new t-nut plate with butyl, reinsert, check for flatness, tighten up doped bolt, trim excess threads, rinse & repeat?
Old 07-01-2021, 07:07 AM   #220
Greetings -- so replacing the TNuts -- is it possible for anybody tp post a quick "how to do it" primer on replacing the penthouse roof nuts with the S/S TNuts - any danger involved ? I'm with DosMars -- Thanks for any help !
Big Grey
allenl
Vanzilla
Glenn P.
