ACR install, sawy barbushings and 2nd handle on door
I got a few things going this summer: finally installed the Blue Sea ACR, with linked battery setting for starting, installed the anti-sway bar bushings, and added an extra handle on my side door. The Blue Sea ACR (Automatic Charging Relay) lets a charge at either battery bank charge the other, as in alternator charging one way, and solar panels the other. Who can also isolate the batteries, or connect them all to start the engine when there's an issue. To use the start feature who need heavy wire, I used 2/0 marine cable. The hardest part was figuring out where to run the cable, and later running it. I've been sitting on these anti-sway bar bushings over a year, thinking that I needed an air hammer. They were a bit of a pain to get the old ones out. I don't have an air hammer, so used just a hammer, bead blaster and a chisel. My Van came with just the lower handle, which is great when you're down below, yet the upper handle is best when you're in the Van. Newer versions seem to only use the upper handle placement. Now I have both. Will head out soon to test all these things. Happy Traveling.
Rob
'97 Ford E350 EB 7.3 PSD
Quigley, Sportsmobile
