Old 07-10-2016, 02:39 PM   #2021
BVerhulst's Avatar
A busy weekend:
A new compressor tank drain valve (anyone have advice for getting oil into the tank to reduce rust?), a towel bar by the sink, the door claw, and prototype Max-Trax mount.
Brian
2009 E-350 Lopes 55
BVerhulst is offline   Reply With Quote
Old 07-10-2016, 02:42 PM   #2022
Jsweezy's Avatar
I love that color.
Also wanted to add something I didnt do but thought for sure I'm not the first person to be told, "Sweet lift kit on that van!"...
Old 07-10-2016, 05:34 PM   #2023
SheepShagger's Avatar
Originally Posted by BVerhulst View Post
A new compressor tank drain valve (anyone have advice for getting oil into the tank to reduce rust?).
If you use it for tires, oil is probably not the best thing to add to the air. As for reducing rust in the tank, crack the drain valve after every use. You'll never stop water in the tank with an OBA system, so best to just drain it.
Old 07-14-2016, 10:59 AM   #2024
LenS's Avatar
Replaced my 12 year old Sure Power battery isolator. Diode blown.
Len & Joanne
The Green TARDIS
Old 07-14-2016, 12:12 PM   #2025
Went to the RV store and left more confused about inverter/chargers than before I walked in................haha........I believe they know less about them than I do
hogasm is offline   Reply With Quote
Old 07-16-2016, 12:12 PM   #2026
Peter81's Avatar
Completed my shower install.
In the original conversion there was a small sink with a shower wand. The PO removed all of that cabinetry but left the opening with the pex piping exposed. He also gave me the leftover pieces and extra vinyl trim to match the rest of the interior.
I decided to add an exterior shower box and extra long hose which gives me the option to shower inside or out depending on the season. I housed this in a cabinet which would also snugly fit the porta potty.
In order to leave the original pex fittings and insulation intact, I chose to run the piping directly into the cabinet rather than back through the wall. I drilled 5/8 holes to route the piping. It fits like a glove and keeps the piping secure.
The biggest chore was getting proper fittings with the pex crimper. It was particularly challenging in tight spaces. Once finished I was relieved to find no leaks and great pressure from the shower wand.
2003 E250 RB40
Peter81 is offline   Reply With Quote
Old 07-16-2016, 01:39 PM   #2027
Any reason that you went with another isolator rather than a separator?
...just curious....
Old 07-22-2016, 05:51 PM   #2028
skyrat's Avatar
Well, we are finishing a three week tour of Lassen, Bend, Olympic Pennensula and the Oregon Coast. We made an appointment to speak with Peter at SMB West for this morning, as we would be nearby on our way home. We wanted some solar info. Well while we were there we asked Peter if they could install it today and Peter said yes. So we waited around a few hours while MoMo got a solar upgrade. When finished the solar was out- putting 8 amps. The mounts look beefy and the spring adjustment will make popping up the penthouse easier.
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
skyrat is offline   Reply With Quote
Old 07-22-2016, 05:56 PM   #2029
KTMRIDER's Avatar
Very nice George! Solar is so worth the money...
KTMRIDER is offline   Reply With Quote
Old 07-22-2016, 09:38 PM   #2030
skyrat's Avatar
We were needing it bad when at Point Sublime on the North Rim without moving for almost 3 full days... Pricey, but hope to get it back in convenience and hopefully a longer life on the Lifeline battery I installed earlier this summer. Just got in and home for a bit now.
Eric,
How is your rig handling? Mine took a day or two to settle in and I am happier than ever with the ride and handling. The rear suspension is more active than ever, but it is not rough at all. Corners and turns at high speed very well for us. It was good before, but now it is way better. Stance is better too!
George ><>
