Old 11-13-2016, 06:53 PM   #2151
simplesez's Avatar
Originally Posted by TexGX View Post
Changed the oil/filter, fuel filter and air filter. The fuel filter was interesting. I got it done then started the engine and had fuel leaking everywhere. After some time trying to figure it out, I realized I left the water in fuel valve open. Closed it and all is good. Well not the spot on my pavers left by the fuel. I need to figure out how to clean it. I am glad I know how to do it, but will probably pay to have it done next time.
How often do you replace fuel filter?
Fuel filters go a long way. 100k plus is ok if you use good fuel. If you buy no name brand fuel then at least half that.
Old 11-13-2016, 07:35 PM   #2152
skyrat's Avatar
Restrung a day nite-shade the other day. I used traditional shade cord instead of the wire that many here have used. It went well with no problems.
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
skyrat is offline   Reply With Quote
Old 11-14-2016, 06:52 PM   #2153
ridintall's Avatar
Disabled the seat belt chime.
Sent from my SM-T810 using Tapatalk
ridintall is offline   Reply With Quote
Old 11-14-2016, 08:25 PM   #2154
BVerhulst's Avatar
Do tell: how?
Brian
2009 E-350 Lopes 55
BVerhulst is offline   Reply With Quote
Old 11-15-2016, 07:56 AM   #2155
Blue Sea Seperator
Ordered the seperator to replace the sure power which is now 9 yrs. old.
07 E-350
patrick51 is offline   Reply With Quote
Old 11-15-2016, 04:42 PM   #2156
A great move, did the same to ours years ago, ya don't need the belt at crawling speed, especially when reaching behind for a cold one in the desert!
07 E-350
Old 11-15-2016, 05:38 PM   #2157
ridintall's Avatar
Straight from the owners manual. 2013 E350.
Old 11-16-2016, 04:47 PM   #2158
joey2cool's Avatar
Replaced my LT245/75R16 DynaPro A/S tires after seven years (OEM with van purchase via SMB Fresno with a 60K mileage limit).
The tire owner's manual said to change them out after six years if you haven't worn out the tread by then. The tread was still almost like new - right up to Lincoln's nose. However, there were a few serious small cracks in the tread on at least two of the tires and one looked nearer to a puncture it went so deep. So, better safe than sorry after only 30K miles.
I had Sears install four LT245/75R16 DynaPro AT-M tires for $688. Consumer Report's 2016 magazine rated these pretty high (just 2-wheeling, but need the M+S certification for my area). Various auto web sites gave them pretty good reviews too. The ride is much smoother than on the A/S tires and it's a tad bit quieter too, both of which make me very happy.
We'll have to see how they wear but it's likely that I'll hit the time limit again before hitting the 50K mileage limit on them. If so I will switch one out for my OEM spare which would be 13 years old by then. That's about as much risk as I can stand.
Silver Bullet
joey2cool is offline   Reply With Quote
Old 11-22-2016, 09:13 AM   #2159
Replaced water heater anode
Every step of the journey in these vans is a learning experience for me...
I finally got around to digging into the suburban water heater for some maintenance & it looked to be long past due! The swap out took just a few minutes including flushing out the tank (didn't buy the tool to flush out just used the hose). The system seems to work better now & I'd guess after all the deposits i flushed out will taste better too...
I was surprised by how much water was in the heater tank after I pulled the anode - I had never done this when winterizing the van via a gravity drain...
All in all a well spent $15.
dick is offline   Reply With Quote
Old 11-22-2016, 09:34 AM   #2160
I am eagerly awaiting the arrival of a set of 102" ATS running boards for my 03 SMB EB. Has anybody done an install on these? I understand they need to be cut down to fit.
plaurie is offline   Reply With Quote
Ann the Van
Bongo
TumbleWeed
Sarah
