12-13-2019, 10:21 PM
#2901
Absolutely nothing... Although, I did go out and just look at it. I mean really took a good long look at it. I admired it for what it is and what it will be when I'm finished with it.
What is it about owning one of these things? I don't want to get all mushy, but damn, I love my van!!!
Friends Don't Let Friends Do Stupid Things Alone
12-20-2019, 11:26 AM
#2902
I installed these Ridgid flush mount back up lights. I bought the kit with harness, three way switch and relay. They can be turned on separate from the reverse lights, or set the switch to only come on when I throw it in reverse or always off.
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
12-20-2019, 04:16 PM
#2903
Been thinking about adding some backup lights. What is the Rigid model number that you used?
Larrie
12-20-2019, 06:32 PM
#2904
Rigid Industries 980033 SR-Q PRO Hybrid LED Flush Mount Backup Light Kit.
73 BMW 2002 O=00=O
12-30-2019, 03:46 PM
#2905
I replaced the drivers side outer tie rod end (2wd w/Camburg kit.) I didn't know why the adjusting sleeve wouldn't stay tight on that side, but apparently it hammered the threads pretty good as the o.d. of the old one was maybe .020" smaller than its replacement. Hopefully that annoying rattling feeling is gone for real this time.
While looking over the front end, I found the lower heim joints in my Fox 2.0"s have some play too, I'll replace those when I'm ready to send them back to Agile for another re-valve, I already have their V5 (stiffest) valve stack, but they could use some more on the compression side... I know, these big vans weren't meant to go fast offroad! As it is, I blow out the upper shock bushings (stem mount) once or twice a year. A 2.5" shock would be more appropriate, but I really don't feel like putting in the work necessary to fit them. Upper balljoints are starting to show some play, so I need to address those soon. Rear leafs are gradually turning into "w"s so I had my neighbor throw another short leaf on the bottom and switch my 2.5" block for a 3" to hold me over until I'm good and ready to spend the dough on new leaf packs and ditch the blocks altogether (possibly considering going with Weldtec's leaf packs.) Honestly, not too bad wear and tear for 45k miles (since all suspension/steering components were replaced, 140k total) with at least 5k spirited paced offroad miles on those parts.
01-03-2020, 08:51 PM
#2906
Replaced the fan in the little Magnum inverter. The original fan has been making a terrible sound at medium rpm for a few years and is destined to fail at an inconvenient time. This was a nice little success in the middle of the conversion to lithium project, which is turning out to become an epic.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
01-14-2020, 10:32 AM
#2907
Cabinet Front Facelift
Slow progress, but completed tooling all the rails, stiles and panels out of hickory. These door fronts will be glued up, sanded and have polyurethane applied before replacing my factory SMB melamine doors. Pictured doors will replace the under sink, pantry and under pull out couch X2.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
01-14-2020, 01:16 PM
#2908
Ordered up and having a John Woods Towmaster H/D 4R100 transmission installed at a mechanic as I write this up in Orange Grove, CA.
This was more of a preventative item than out of necessity, although I’m right there in millage when these 4R100’s start seeing issues, 180K. We towed our camper up to AK and back this last summer, and plan to continue towing it, placing a heavy strain on the trans. Will have piece of mind knowing I won’t have any issues moving forward, especially when down in Baja this winter(although not bringing camper down).
The mechanic came highly recommended by John as one of his preferred installers and friend for over 20 years, that says something, so hopefully everything goes to plan! I’m having him tackle a bunch of other items as well, mostly maintenance items-brakes, fluids....
Thing looked super nice! A shame he hides his stamp on the flywheel, but not really anywhere else to put it!
01-15-2020, 10:44 AM
#2909
Originally Posted by REF
Ordered up and having a John Woods Towmaster H/D 4R100 transmission installed]
Excellent!
01-15-2020, 11:30 AM
#2910
Ordered up and having a John Woods Towmaster H/D 4R100 transmission installed at a mechanic as I write this up in Orange Grove, CA. ...
I can't recall if you've upped you trans cooler. It would be a great time if you haven't. In my Excursion (BTS transmission), I went from my 7.3L based trans cooler to a 6.0L trans cooler. Factory Ford, and simple to swap.
Picture from Ford-Trucks.com
https://www.ford-trucks.com/forums/1...0-7-3-a-2.html
