Old 09-08-2011, 02:18 PM   #731
Tapatio's Avatar
Re: What did you do to your SMB today?
Rhino lined front bumper and aluminess standard box. I hate chrome and the standard box was getting all scratched up by the gas cans.
Callsign KK6GIY
Old 09-08-2011, 02:40 PM   #732
Tapatio's Avatar
I found a subwoofer that fits perfectly behind the drivers seat. The paired amplifier fits underneath the seat. This configuration does not interfere with the seat in any way and provides excellent bass for the cab area, not boomy at all.
http://www.pioneerelectronics.com/PU...ount/TS-SWX251
http://www.pioneerelectronics.com/PU...ries/GM-D7500M
p.s. I don't play loud music while I'm camping so don't hate me for liking a nice sound system.
Callsign KK6GIY
Old 09-08-2011, 06:53 PM   #733
kmessinger's Avatar
Send a message via Yahoo to kmessinger
I added a new symbol to the TomTom. Yes, it is a Sprinter!
Now I can follow myself around!
kmessinger is offline   Reply With Quote
Old 09-09-2011, 04:48 PM   #734
After twice having the front driveshaft hit the oil filter and housing and cause an oil leak, I installed a SMB/AMSOil dual remote filter setup.
I used different fittings than the ones that AMSOil supplies at the engine end. I noticed the oil lines go down, then curve up. So, I used a 90 degrees fitting so the hoses are aimed in the right direction.
You can see the 90 degree fittings. $50 for both.
And I mounted the filters up above the transfercase skidplate.
You can only see the edge of the crossmember the skidplate is mounted on. The skidplate goes from the crossmember past the back of the transfercase. It is a little tight getting to the filters, but they are well protected.
The hardest part of the modification was making a spacer to mount the filter block away from the frame and body bolt. A piece of 2x3 steel tube did the job after I cut a 3" hole offcenter in it to clear the body mount.
Old 09-10-2011, 09:28 PM   #735
tmtm's Avatar
Recently had Action Van add light-bar and lights.
Huge thanks to Greggd for help with this!
tmtm is offline   Reply With Quote
Old 09-11-2011, 06:53 PM   #736
Today I drove it our local mountain; it ran great. Then I tried to get the nuts up to install the bigger tranny cooler.
Any tips?
C.
c7train is offline   Reply With Quote
Old 09-11-2011, 10:07 PM   #737
Kzinti2's Avatar
Installed the penthouse corner braces I fabbed yesterday
viewtopic.php?p=68099#p68099
2004 SMB w/Penthouse - Ford 2wd RB 6.0 - new to us in 2011
Kzinti2 is offline   Reply With Quote
Old 09-11-2011, 10:44 PM   #738
ANZAC's Avatar
- messed around with ScanGauge
- installed Mag Hytec rear diff cover and LE1605 SAE110 oil, Ford Racing LSD additive, diff shudder gone
Sportsmobile-less.
Old 09-12-2011, 07:07 PM   #739
Raised Penthouse for tri yearly cleaning of exterior canvas and waxing of roof top , followed with waxing all door jambs and cleaned all door seals and 303d them . Removed and rotated Tires along with cleaning of Brake Disc's and Caliper's .
Greggd
Old 09-12-2011, 11:59 PM   #740
This was done several weeks ago and it's not my SMB, so lets just call it, What did you do to someone elses SMB a while ago?
So a few weeks back my SMB had to share the driveway with a visitor. A friend of mine ask if I could do some of the mods to his van that I did to my van. He dropped off his van for a few days and this is what I did to it.
First I installed a few hooks, 2 on the PH ceiling (these are very nice stainless steel hooks) this take the place of hanging something from the roof latch. 2 similar hooks in the very back of the van and a clip type right behind the drivers seat.
Then I installed a 3 gal drinking water tank with a custom breather valve.
And finally I cut two holes in his fenders and installed these vents.
I learned a lot when I did mine and I must say, I think I did a better job on his.
John
