It's a great deal on a winch...just DO NOT use the included bolts to mount it! They're trash; broke at least two even with a torque wrench. Square nuts are sorta hard to find, but got some at Ace and put new bolts in.
There was a need to do a bit of cutting, otherwise it's hard to get your hand in to operate the clutch lever. Most of the front hitches are installed in about the same way, the geometry works pretty well. You might be able to get it a tad lower. The grill guard I have makes it a pain to remove the thing, since that has to come off too. If you have just the bumper it's much easier.
Something else to consider: mounting the winch vertically, with the bottom facing forward. That cuts the height by about 2". The issue would be access to the clutch, and inspecting the line and such. So you might have to trim the upper rear, but it wouldn't be visible. I also thought afterward that I could have modified the clutch lever so I wouldn't need such a big opening.
I got quite a good deal on the dyneema line from
http://truckandwinch.com (they have an eBay store as well, and some stuff was available there that wasn't on their regular website). Very responsive customer service. The line was $160, and I got a new fairlead as well. So not that bad. It came with a fixed hook, a rock guard, and an eyelet fixed to the end I had to chop off to fit it into the hole on the HF winch (I think some of the older HF models used a different method of connection). If you went with a thicker line than stock (3/8" IIRC) then fixing that end would be an issue. I probably didn't need the dyneema, but once you've used it you'll never go back to wire rope. And with the weights involved here I did not wanna mess with wire again. It's just hairy.
