Originally Posted by Lilnuts2
If you don't mind
Which rear axle do you have?
Did you have to change your Trans sensor wiring?
Did you have to change your rear driveshaft length?
Can you keep your engine cover cup holder in place?
Is your crossmember 100% fab or a modded one?
Any clearance issues with the drivers front tire?
How far does the trans hump protrude above the floor line?
How far into your engine cover did you have to cut?
Is the engine cover removal any more complex?
Was the brake booster a bear to work around?
Can you show us a little more on your Trans tunnel?
Thanks for sharing.
I have a parts truck with a 150,000 mile 7.3, ZF6 4x4 and am thinking about converting it all to the van.
rear axle is from a 2006 F350
Trans sensor wiring is un changed but do have to jump pins so the computer thinks its in park.
Front drive shaft from the manual is needed. Rear needs to be lengthened.
stock cup holder could work if you put a weird bend in the shifter. but i went for comfort shifting and no cup holder.
trans tunnel is very small only 1" of rise 6" wide 6" long angled.
the engine cover is not cut. but the shifter plate bolts to it so it does make removal a bit more of an task. the shifter does need to be removed to remove the cover.
bake booster was fine. the big issue is having the right geometry on the pedal mount to have the pedals line up nicely and right amount of throw.
( I had this made by a friend that is a very talented fabricator along with the tunnel, trans mount and the fender cut.)
the cross member is 100% fabbed
0 clearance issues with the fender.
