Originally Posted by porschedpm
A Renogy 40amp DC-DC Charger is the only link between the two battery systems.
The specification for the Renogy DC-DC charger is:
Input Voltage Range: 8V-16V
So it is more than disappointing (i.e alarming) that the charger when activated will drive the source battery to oblivion by fully discharging well below 12V. I never like the fact that this DC-DC charger would even function down at 8V but even worse this doesn't even seem to be a charging limit!
As a rule of thumb, you don't want your start battery to be discharged which means you are below 12.8v (at the start battery terminals). However, in my own calculations of current drop and wire sizing for a 40A Renogy located in the rear of an E-350 with a Lithium battery, the numbers work out to about 13.5V at the start battery terminals else the current demand and voltage drops become unwieldy.
In the table below you can get an idea of how current demand goes up at lower Alternator outputs translating to lower start battery terminal voltages. The table was generated using 3% nominal voltage drops in all wiring.
The only time you would want to be DC-DC charging at idle is in the 20 amp mode. At 40A charging and 13.5V at the start, battery losses are exceeding 3%
Summary Analysis (sorry for the poor formatting the website pulls out blank spaces)
________________________ 40A Charging_____20A Charging
______________________Hi RPM___Lo RPM___Hi RPM___ Lo RPM
DC-DC Demand_____A___40________40______20_______20
Start Battery_______V___14.6______13.5_____13.5_____12.8
DC-DC_IN_________V___14.17_____13.04____13.27____12.5 6
Alternator Demand__A___51.5______56_______27.5_____29
Voltage Drop_______%___2.93_____3.44______1.7______1.88
