Old 04-22-2021, 09:48 AM   #11
oldbonesclimber's Avatar
My understanding is you should get the number off the tag on the original harness ( located approx under the coolant bottle ) to verify it is the correct one.
oldbonesclimber is offline   Reply With Quote
Old 04-22-2021, 11:07 AM   #12
I sourced mine in 2015 from AutoNation Ford for $664 and now $750. 6C2Z-12B637-UA is the part # I have. You can find it cheaper on ebay if you decide to go that route but I doubt any dealer will beat AutoNation's pricing.
I believe it's the same one for a 2007 but for sure as mentioned confirm with the VIN. Also, the glow plug harnesses are cheap and might as well replace those. Removal almost mandates replacement because the clips to the glow plugs are plastic and break.
2011 VW TDI Golf for hwy fun
Old 04-22-2021, 12:21 PM   #13
ravensix's Avatar
Originally Posted by oldbonesclimber View Post
Try these guys
https://www.fordpartsgiant.com/parts...nsmission.html
7C2Z-12B637-AA or 6C2Z-12B637-UA
Tasca Ford also has them listed That is where I got mine.
For future reference:
Ford part number: 7C2Z-12B637-AA (Engineering part number is 7C2412B637DA, which is what you might find on the harness.)is an obsolete part number.
Ford part number: 6C2Z-12B637-UA (Engineering part number is 5C2412B637UC, again what you will see on the harness.)
ENG PART: 5C24 12B637 UC____________ ORIGIN: WERS REGION: N USG STAT: _
Eng Name: WIR ASY ENG CONTR SNS & FUL CHG PT: _ PTO: ____ VL: __
Svc Part: 6C2Z- 12B637-UA USG IND: _
P In Out
t Vl Yr Yr Feature Descriptions Feature Descriptions
T E4 06 08 ECONOLINE NAVISTAR 6.0L OHV DI NA V8 DSL
350 SERIES 50 STATE EMISSION REQS
450 SERIES 50 STATE EMISSION REQS
T E4 08 08 ECONOLINE NAVISTAR 6.0L OHV DI NA V8 DSL
450 SERIES 14,001 LB AND OVER GVW
450 SERIES 8601 LB THRU 14,000 LB GVW
ravensix is offline   Reply With Quote
Old 04-22-2021, 12:40 PM   #14
ShuttlePilot's Avatar
Around 2 years ago I spent some time thinking about buying a new harness to be ready for the day in the near future I would need to replace my crumbling original. The challenge I ran into was pinning down the exact part number for my 2005 van. Ford parts tech searched by vin and would come up with two options. This wasn't ideal unless I had the old one off and could compare, but I wasn't ready to replace it then. I wanted the correct one on the shelf.
oldbonesclimber is correct there is a tag on the harness around the lead that plugs into the FICM. Located under and center of the degas bottle. However on mine it is an international part number that I haven't been able to get anyone to cross reference.
Through internet searching late at night and a few phone calls to ford parts I was able to come up with the following part numbers based on date of manufacture.
5C2Z-12B637-U = 11/2004 - 10/2005
6C2Z-12B637-UA = 10/2005 - 06/2007
7C2Z-12B637-AA = 03/2007 - AND UP
Therefore my van having a date of manufacture of 03/2005 would be the 5C2Z-12B637-U, maybe.
The reason I didn't just purchase and throw on the shelf is I haven't been able to verify it, and stuff happened in life over the last 18 months. It would be great if someone with access and intimate knowledge could verify these part numbers based on date of manufacture. And even better could lay them out on the floor at Ford and look to see what is different between them.
Ravensix, any help you can provide the 6.0 captains is much appreciated.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 04-22-2021, 12:58 PM   #15
ravensix's Avatar
6.0 wiring harness service part number & engineering part number
Remember service part number is what you order at the Ford parts counter, the engineering part number is what you will find on the actual harness.
Some service part numbers had engineering part number updates during build times, under the HISTORY section you will see the different engineering part numbers by date used during build periods.
SERVICE PART: 5C2Z- 12B637-U____ WIRE ASY
HISTORY: Y PRODUCTION TIMING REGION: N
A X-REF X-REF PROD PROD CUR
C ENGINEERING PART ORGN EFF IN EFF OUT EFF IN EFF OUT PRD
5C24 12B637 UB WERS 03/14/05 08/02/04 Y
5C24 12B637 UA WERS 11/11/04 03/14/05 08/02/04 08/02/04
ENG PART: 5C24 12B637 UB____________ ORIGIN: WERS REGION: N USG STAT:
Svc Part: 5C2Z- 12B637-U USG IND:
P In Out
T E4 06 ECONOLINE NAVISTAR 6.0L OHV DI NA V8 DSL
T E4 05 05 ECONOLINE NAVISTAR 6.0L OHV DI NA V8 DSL
350 SERIES 2005 JOB #1 PROGRAM CONTROL
350 SERIES 2005 JOB #2 PROGRAM CONTROL
450 SERIES 2005 JOB #1 PROGRAM CONTROL
450 SERIES 2005 JOB #2 PROGRAM CONTROL
SERVICE PART: 6C2Z- 12B637-UA___ WIRE ASY
5C24 12B637 UC WERS 06/13/06 12/14/05 Y
P In Out
SERVICE PART: 7C2Z- 12B637-AA___ WIRE ASY
7C24 12B637 DA WERS 02/27/08 01/07/08 Y
7C24 12B637 CA WERS 04/17/07 02/27/08 09/04/07 01/07/08
7C24 12B637 AA WERS 10/23/06 04/17/07 09/04/07 09/04/07
ENG PART: 7C24 12B637 DA____________ ORIGIN: WERS REGION: N USG STAT: _
Svc Part: 7C2Z- 12B637-AA USG IND: _
P In Out
T E4 07 08 ECONOLINE NAVISTAR 6.0L OHV DI NA V8 DSL
Hope this helps, got to get back to work, pushing parts to dealers.
