Originally Posted by basssears
Care to share what is on your list? New AGM batteries for me has lead to some upgrading of my charging sources (to accommodate AGM specific voltages), have upgraded my MPPT, a DC-DC charger is next on the list but I'm still with my old InteliPower and the Charge Wizard, can see that it does in fact storage charge at 13.2v which my Lifelines say they like but I guess the desulfation does bug me a bit.
-- Bass
The specifics I look for in chargers are this.
Battery type programmability
It is unfortunate that battery manufacturers and charger manufacturers are not on the same team. You can see a real difference in settings, so it is best to look at the individual charger you are looking at and check those settings with the specifications of your battery. There are at least two common AGM settings alone.
Some chargers will offer you a custom setup where you can program the voltages for the various settings such as Adsorption and Float, this would be even better.
Equalize
Many chargers now count equalize as a forth stage of charging. While that is great, AGM or Lithium batteries don’t need this stage. It is best that you can disable this stage, certainly the automatic part of it. Lifeline does support what they call a conditioning charge, under certain circumstances.
Temperature compensation
This gives your charger the ability to change the voltages of the different stages based on the temperature of the battery.
As one can see from the chart the voltage for charging is much different based on the temperature of the battery. This feature many times will need the purchase of an optional temperature probe. Some chargers may support cold and high temp setting, which while not as good as the temperature probe would be better than most.
Charger sizing
Your charger current should be sized for the size of your battery bank, 15% would be a minimum while 30% would be good for the high end.
If looking at moving to lithium at some point you might want to see if you have more control over the absorption stage. In general Lithium likes to have short absorption stages.
In general I usually find more features on the Inverter/chargers than in stand alone chargers, but a couple of good units are
Xantrex TRUEcharge2 XXA, 12V Battery Charger and
KISAE AC1260 Abso 60A, 12V Battery Charger.
