The holes are stripped out? I would glue thin-ish pieces of wood on the back side of the panel to provide a place for the screws to grab on to.
If you want to do away with that outlet all together, you can replace with standard household stuff. You should be able to find a blue “old work” box at the hardware store that has flip out tabs that will secure the box to the panel. Then you install/wire a standard 15amp outlet.
Good luck
