Fridge Circuit Blowing Fuse
My 2017 SMB is equipped with 2000 watt Magnum Inverter & Progressive Dynamics fuse box (with breakers for a/c side). We have Isotherm 65 refrigerator that has performed flawlessly, but I have a strange problem where the fuse for the fridge circuit blows even if the fridge is turned off.
I first discovered this after the fridge was turned off and the door was in the vent position with the light off. I went to turn on the fridge, but found nothing working and discovered that the 15A fuse was blown. I replaced the fuse and it sat in the same state for several days, but worked when I turned it on yesterday. It ran okay all day yesterday until this afternoon when it apparently blew while the fridge was running.
The only commonality that I know is that internal temps in the van have been 115+ as it is stored in Phoenix. I would never camp like this, but I needed to keep some stuff cold for a couple of days. It makes no sense to me that the fuse should blow with no load on the circuit, and I did not witness it. Is this possible? Any ideas on what could cause this?
