Old 06-21-2022, 05:46 PM   #1
ghetto fireman's Avatar
Goal Zero 3000X
Thinking about ditching the Honda Generator and moving towards the Goal Zero 3000X and a solar panel. Seems like a no-brainer. Any pros or cons from the group ?
Always appreciated
2006 EB SMB " Big Boi “
1967 Toyota Landcruiser FJ-45
1974 Toyota Landcruiser FJ-40
ghetto fireman is offline   Reply With Quote
Old 06-21-2022, 08:26 PM   #2
for anything that large you will need a large panel. I have a 220ah lifepo4 and 312ah li-ion batterybanks and a 240 watt panel was struggling to charge them up in winter, both banks where at about 10 percent for months.
After I upgraded to a 365 watt panel, I was able to get both banks up to 100 percent in about 7 days of winter sunshine.
In summer the 365 watt panel can put over 130ah of power back into the battery every day.
If you have small panels and use the goal zero alot, you might need the generator to charge it back up especially in the winter.
A 365 watt panel or larger are huge beasts, it took up almost the whole roof, but it was worth it, I max out at over 27ah of charge power when the sun is overhead.
jonyjoe101 is offline   Reply With Quote
LiamMobile
Shyll
GIL
Manoel Brazil
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
