06-23-2009, 02:41 PM
#31
Re: Mileage on diesels - BullyDogs - Redline 85 Plus
Hopefully it will take a good grade paper filter as well. That would be very important to me.
06-25-2009, 09:40 PM
#32
Daveb and Scatter ,
I had the Zylstra Air Box installed today and posted photographs in my gallery . Upon completion of the 1 hour forty five minute installation , I left Visalia and traveled to Oakhurst Ca. I noticed a mild difference in low end performance while leaving Visalia and a substantial difference in the top end , how much I don't really know only the Dyno will tell . I can say that at temperatures at around 100 degrees on my return home to Azusa Ca. I was able to cruise with much less heat build up and with a more responsive pedal . Milage seem to increase in spite of the ambient temperatures encountered on my return home , about 1 mile per gallon as near as I can tell . The amount of air surrounding the filter has increased at least three fold with this new system and I am happy with this improvement and will hopefully get it on the Dyno next week , time permitting . Daveb the filter is a high end AFE brand Flanged filter that can be serviced with much more ease than the stock unit and I was very pleased when I pulled the Grapevine at speeds never before obtained . Sean Zylstra is looking for a source of throw away filters and must custom fit the Air Box as the variations from Van to Van vary . I know that both you and Scatter would be more than able to do your own installs with decent instructions .
Greggde
06-25-2009, 11:26 PM
#33
Thanks for the info Greggde. At 1 hour away I'll just let them do the job. So is the filter a typical micro fiber paper? I still don't trust an oil charged type filter like a K&N.
Dave.
06-26-2009, 07:07 AM
#34
Daveb ,
This filter appears to be different Material than the K&M types that I have previously used in my District 37 racing days , very sturdy with a lot of surface area . I noticed this A.M. that it seems to idle along better than before as well , maybe just a placebo , but so far so good .
Greggde
06-26-2009, 12:10 PM
#35
Greggde - Where's the inlet for the new air box. Do they still get it from around the left headlight? If so, how does it provide more air??
Scatter
2007 RB50, 6.0
K1WGB
06-26-2009, 03:37 PM
#36
Scatter ,
Yes it is routed from this same location , the difference is that basically the new filter is suspended in the large cavity that was required for just the box on the stock filter . On my 2007 their are a number of smaller holes in the body panels that will allow some additional air flow . I plan to look around in this compartment for places to enlarge or add additional holes that will not effect the structural integrity . Just the elimination of the large space grabbing bulbous box should make for a difference and if you look at your OEM flat filters wear area you notice a 6 or 7" area only where the air was being funneled thru 2/3 rds of my stock filter was not even being used .
Greggde
06-26-2009, 07:03 PM
#37
Hi guys ,
I added more descriptive photos for the Zylstra Air Box to my Gallery for those of you interested .
Greggde
06-27-2009, 10:01 AM
#38
Can you still use a paper filter? The red filter looks like a K&N rechargable filter.
06-27-2009, 12:41 PM
#39
daveb .
The filter is a aFE rechargeable , Sean is looking for a source of the paper throw away filters for those of you not desiring the rechargeable type . I ran the Van up the San Gabriel Canyon
this morning an found that it pulled the grade with more speed at fewer RPM's and less shifting than previously . Not a huge difference but enough to make me happy .
Greggde
07-09-2009, 02:50 PM
#40
Thanks Greggde for the detailed feedback and pictures.
Will keep this option in mind.
Andrew
