I have tried to contact alternatorparts by mail but they don't answer. Does anyone know how to get in touch with them?
I have a dual set up on my Excursion and 4 batteries. I think it will to much to do the same with the van so I would like to buy the 140 amp from Alternatorparts. This alternator will be just right.
If they don't reply I will check out some of the others.
I have a external velder that I bring around if there is a need, This is driven by a Honda generator.
No, I havn't tried to call them. I live in Norway, so it is most convinient to mail them. Unfortunately i have same experience with some other companies in USA.
Regards
Dog
Good chance your email is blocked since you are outside North America. What used to be the Nigerian Inheritance scam is now an entire spamming industry. They even have sweatshops dedicated to deciphering those funny word code pictures.
X2 on that, Agreed!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
