Re: Transfer Flow Trax-UFS display soldering
rally, i had to do this with my traxx-ufs. its pretty straight forward. A helpful tool is either a solder sucker or solder wick.... that way you can remove the old solder and replace with new. you could also just reheat the pins and add more solder to the specific pins detailed in their bulletin.
it took me about 5 minutes and has worked like a charm since... for about two years so far. I saw your post was from a while ago.... did you get it to work?
2000 EB50 4x4, V10
