Originally Posted by Ruthless
I figured out where it was leaking. Duh, run some water over it and watch. It’s leaking through one of the grommets on the back where it attaches to the swing bar.
Yeh, kind scarry when the obvious just seems to elude you - gets worse with age (talking from experience!
My box leaks a little as well (but it's the older version). I just drilled five 1/2" holes (2" in from each corner and one directly in the middle).
Holes will serve a dual purpose soon; Box gets pretty hot on the inside when in sunlight, so I also purchased (and hopefully installing his week sometime) a 4pk of Marine cable vent covers to be mounted on the back/top of my box to allow some venting since I keep fuel additives inside along with other stuff. The 5 holes i drilled in the bottom of the box allow any liquid accumulation to drain, and air to come in. The vents across the top/back allow the hot air to escape.
https://www.amazon.com/Marine-Clamsh...ng%2C94&sr=1-4
