05-19-2012, 06:14 PM
#31
Re: Flash lights
I've got some very bright flashlights, but when camping most useful, by a landslide, is a headlamp. Read with it, work under the SMB with, walk with it, cook with it, play cards, etc. -- all with two hands free.
I have two - a Zebralight and a Surefire Minimus. Both get a lot of work around the house (and especially under it).
If you want to go nuts on information, check out Candlepower Forums.
John
06-04-2012, 08:51 PM
#32
Re: Flash lights
Dave,
What brand of LED was it?
terralux if I remember. Only 300 lums but throws a good beam. It's better than my little 850 lums light.
06-04-2012, 09:09 PM
#33
Re: Flash lights
Absolutely.
I've got headlamps all over the place and use them 5-10x more often than a standard flashlight.
R
2006 SMB 4x4, EB-51, 6.0psd
06-04-2012, 09:29 PM
#34
Re: Flash lights
Absolutely.
R
Hate it when someone stands there talking to you with one of those blasting in your face
06-05-2012, 08:03 AM
#35
Re: Flash lights
I got a streamlight from bear mountain.com. It has a 12v rechargeable battery and will set newspaper on fire! it's quite expensive but it will cause extreme envy if you show it to a cop.
"What'$ that funny noi$e?
06-05-2012, 09:39 AM
#36
Re: Flash lights
06-05-2012, 10:55 AM
#37
Re: Flash lights
06-05-2012, 01:19 PM
#39
Re: Flash lights
Originally Posted by dig255
That rocks!!
However a run time of 5 minutes ........
06-05-2012, 02:03 PM
#40
Re: Flash lights
Sounds like a GREAT tactical light but for “looking what went wrong under the hood” or “the wife walking over to the restroom”, 5 minutes won’t cut it.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
