Originally Posted by E-350
Good Morning!
Just reading this thread as I‘m about to renew my floor.
As I have access to all body mounts I‘m planning on replacing them after 280k miles [emoji23]
Can someone share his experience how it works? From what I understand I have to remove the fuel inlet, then loosen up all body mounts, lift the body up by 1/2“ and swap em out?! Is that all?
I also watched a video on youtube for F-series and they mentioned not to use an impact?!
Any insight/ video/ warning welcome!
I wouldn't recommend you do it that way, you could run into misaligning/shifting the frame to the body and get the stupid crab effect. Surprisingly, its very common!
What I would do instead is do one side at a time and gently lift the body on that side just enough to replace the body mounts. Mark the frame to body at key clear places of your choice and make sure frame/body don't shift. Tighten back up to correct torque (don't use your 1/2" impact and compress the bushing) and move on to the other side. Mine was 70 ft.lb. from memory. Look it up and be sure.
Not sure about needing to remove the fuel line but start and see if you do.
Hope this helps and good luck removing those bolts!
