Re: Factory rear A/C and heat into an EB cargo
Really appreciate all the information and quick reply. Crawled around the vehicle today but it was kinda dark and snowing (November) so didn't really learn much more than I already knew. The van is bare from the front seats back, including the headliner. My thought was to pull the evaporator and fan from the black housing and park them in a cabinet base behind a grill to just get some cool air to the rear. The lines and everything under the hood pass a cursery visual inspection, once I get it inside I can get a better look. Seems like I'll need to get it into a real shop that can check the system, unfortunatly that involves a ferry trip and a bit of a drive, so probably won't happen right away. The heating unit and all the wiring have been replaced, I plan to detour the heater hose thru the hot water tank on the way aft. Again, thanks for the comeback, I'll let you know how I make out.
