Old 10-12-2016, 10:07 PM   #1
E250's Avatar
Fans And Vents, what to use?
Hi All, I see so much about FantasticFan, but they seem to be made for giant RV's not my E250, I don't what that giant profile sticking up and they are pricy. I notice they do sell a vent only w/out motor. Any advice on a lower profile vent sized for a van.
PKP 2000 E250
Basic wht Cargo van like every other
one you've seen, soon to be way cooler
Slowly building interior
E250 is offline   Reply With Quote
Old 10-12-2016, 11:42 PM   #2
Abitibi's Avatar
Look at MaxxAir. More robust, lots of feature, reliable, low profile available and they often go on sale (Amazon). Love mine!
Sent from my SGP511 using Tapatalk
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
Abitibi is offline   Reply With Quote
Old 10-13-2016, 05:38 AM   #3
Wbp
I installed the MaxxAir in my van I can leave it open during the hot days to keep inside temperate down while parked. It also has the reverse fan so I installed pop out rear windows and just open them and put the fan on exhaust and it gives a nice breeze through the the van. I also added two small fans inside and they work great to cool off the inside of the van. MaxxAir it worth adding.
Wbp is offline   Reply With Quote
Old 10-13-2016, 08:29 AM   #4
LenS's Avatar
Have had Fantastic Vents for 30+ years and they have worked fine. I do prefer the 10 speed over the 3 speed because of the reduced current draw. Not sure what you are talking about when you say "they seem to be made for giant RV's". As far as I can see the MaxAir and Fantastic Vents dimensions are similar. They both are the industry standard for quality. Unless you are refering to optional vent covers. I would not buy any brand w/o a motor to pull or blow air I think they are a waste of money. What ever you consider I would recommend you compare CFM and current draw of the fan. The Fantastic Vent I have draws less then 1.6amps at the highest speed and pulls 960cfm.
Len & Joanne
The Green TARDIS
Old 10-13-2016, 08:55 AM   #5
I have the Fantastic installed in my GTRV top, and it works fine. It might be nice having more speed choices and less current draw on the very lowest speeds, but I don't run it all the time and my solar panels keep the batteries topped off most days. It does stick up a bit, but the rack I built protects it from tree branches etc. All in all, no complaints, but the Maxxair may be better for your use if you need the features it offers.
Old 10-13-2016, 04:54 PM   #6
dmeade0's Avatar
Google:
Ventline VP-543
I've attached a picture of it installed
David
05 PSD SMB_4x4 RB-50
dmeade0 is offline   Reply With Quote
Old 10-13-2016, 05:04 PM   #7
larrie's Avatar
We have a Fantastic Fan that works great. Have also added a Fantastic Vent, no motor. Most of the time we have just been opening the smoked lids on them and a couple of windows with motor off. That seem so to provide enough ventilation to keep the van from getting overly warm on hot days.
Larrie
Old 10-13-2016, 05:09 PM   #8
dmeade0's Avatar
Here's a slightly less cluttered picture with the vent down.
Old 10-13-2016, 08:15 PM   #9
LenS's Avatar
VP-543 specs: 100cfm 1.5 amps
Len & Joanne
The Green TARDIS
Old 10-14-2016, 12:32 PM   #10
E250's Avatar
Thanks all, there is a 14" x 14" hole already cut for a Heng or old style Elixir vent, may be easier to replace it, also much lower profile than the Fntstc fan, I'm trying to retain some stealth and low profile
PKP 2000 E250
Tags
build, fans, vents
