Speedometer stuck
It’s most likely a faulty speed sensor, not a big deal, but you’ll want to swap that out if it’s bad. Any other symptoms? Can cause issues with cruise control not working and transmission shifts. Pretty sure it’s located on the drivers side of the transmission towards the rear.
Might just be a loose connection too, unplug the wire harness from the sensor and make sure there’s no debris, shoot some dielectric spray on the contacts and plug it back in, see if that does the trick
